It is currently Tue Jul 22, 2025 1:02 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jun 19, 2007 4:36 am
Tony, I just wanted to add my thanks to you for posting this. Much appreciated.
Todd Rose
Ithaca, NY
PostPosted: Tue Jun 19, 2007 12:24 pm
Last Name: Garrish
[QUOTE=Kelby] Wow, Tony, thanks for posting this!
Can you explain what you meant by the following: "especially if the rest is not being blacked out (some will veneer the rest to match the binding, I have yet to do that, but that is what Ryan does." I didn't understand what this meant.[/QUOTE]
I'm not sure if someone answered this, but on Kevin's (Ryan) guitars, it looks like the binding just widens over the armrest and then thins back out on the other side. So the armrest is veneered with the binding material to achieve the effect (and it's really hard to find the joint on Kevin's work)
Bob Garrish
PostPosted: Tue Jun 19, 2007 3:19 pm
This was a fantastic thread, thanks you very much!!!
Jeremy
PostPosted: Tue Jun 19, 2007 3:37 pm
Tony,
I just got approval to make one on an upcoming build.
I'm new to building so I want to be sure to give credit where credit is due.
Can I publicly acknowledge Grit Laskin and you as the developers of this?
Do I need to get permission first?
If it doesn't work out, can I blame you?
PostPosted: Tue Jun 19, 2007 11:01 pm
Absolutely Steve .. Grit is THE man. He has copyrighted the names Laskin Armrest and Ribrest. Other than modding his design approach, I have no rights or take no credit - nor wish any - but thanks just the same. I did contact Grit (and have met him around here a couple times, he lives about a half hour away here in Toronto), and he has no issues with anyone making guitars with either rest - he would however appreciate the use of the names Laskin Armrest and Ribrest. Send him a picture even when you are done, he is a most gracious and giving person.
Sure go ahead and blame me when it doesnt work out . Then get the bondo and black paint ...
PostPosted: Tue Jun 19, 2007 11:20 pm
Thanks Tony Great tutorial
That ribrest seems to be the same color as the binding. Did you veneer that area?
PostPosted: Wed Jun 20, 2007 12:29 am
Ah .. no .. that one is a spanish cedar block, very brown braz B&S .. so I tinited the lac to that shade and sprayed the colour coat after getting the first 5 or 6 down, and then flat sanding them. Then shoot another 5-6 over it (and the rest of the body) and be careful not to sand/buff thru to the colour coat. I did the same on this one, the block is mild curl soft maple, and the B&S are coco, then sprayed the block to match in, as I didnt want it to stand out, but blend in.
